- Los Gatos, CA
I ordered the OEM Mikuni cross-bar high speed needle (P/N BN44/167). The taper angle is different than the OEM needle, it is slightly steeper. And the very tip is smaller on the Yamaha needle.
The needle "seats" about halfway up on both, if you look close you can see a black line on the new cross bar from where it seated. But otherwise it fits correctly, length for the spring is the same, etc.
What difference will this make, if any?
The same turns out should be the same flow, but it will just be more sensitive to adjustment with the steeper taper?
I really want to move to a cross bar needle, and the common t-handle needle made by Jetworks is long and heavy and can vibrate out over time. I also prefer OEM parts, and the Mikuni screw lets me keep the choke.
