- Sebastian, FL
I am posting this here because it only happens when I surf ride, in the lake not only does the ski pretty much never shut off unwanted but it will start right back up if it does.
The problem I am having is when the ski stalls out it is usally a pain to get started and I think impossible without the primer. This could happen because I fall off and the tether comes off or I loose it trying a re-entry and the ski gets hit by a wave. If the thing takes on a bunch of water I understand why it would be hard to start/need the primer, but for this problem to happen it does not have to take on water. I was going to try changing the jetting.
It has a Mod B pipe (I know limited would be better for my setup but I could not get my hands on one) and carbon tech reeds.
I am now riding mostly at the ocean in NJ so water temps are prolly in the 60s at this point. Currently it has a 137 main and 72 pilot, 95g pop off spring. The lows are at 2 turns out and the high 2 and 3/4. It is just a little lean like this in the ocean but good in the lake.
Any suggustions on if this sounds like a jetting issue or any other advise? The fact that this never happens at the lake leads me to believe it has something to do with the colder water/ salt water.
Im just tired of getting owned by a wave when if the ski would just start right up it could be avoided.
Thanks guys.
Thanks guys.
