- sask, canada
Ski was running perfectly fine until tonight, I rode it for about 10 min, just finished babying it to warm it up, when a boat went by. I hit their wake a couple times getting some decent air, after the third time I jumped it my ski started running like crap. I thought it had possibly ingested some water that was sloshing around inside the hull so I continued to ride for another minute or so, but it didn't clear up. Rode it to shore to investigate and I couldn't see anything wrong. Fired it up on the dock and it started to run away on me, so I instantly grabbed the throttle and hit the kill switch and it died. Pulled the plugs and the mag cylinder looked lean. Up until this point both cylinders were on the rich side, I even used an inspection camera to check piston wash yesterday and my engine builder even confirmed that it was still rich when I sent him the pics. I double checked all my mixture screws and they're all good, I decided to richen them back up some more and try it out. Put it back in the water and it was still running like
, almost like it was running on one cylinder. I grabbed full throttle a couple times and after a couple seconds it would catch and almost rip out of my arms but as soon as I let the rpm's drop down it would run like crap again. At this point I loaded it up and took it home. At home I checked compression and spark and they're fine. I have good fuel flow to the carbs (took off the return lines and turned it over and had lots of fuel coming out). The next thing I guess will be pulling the ebox and making sure all my grounds and everything are still good unless someone has any other suggestions?
I'm running MSD total loss and Full Spec 49's.
