HELP removing plexus from ebox mount
JT_Freeride
John Tetenes @Jtetenes
Long Island
Hey guys I need some insight I'm trying to remove a carbon ebox mount for a rickter its glued in with plexus I've tried a heat gun and got the bottom half to come off but the top seems to be a little more difficult. The carbon started to split on the mount so I stopped but now I'm stuck. Any help is very appreciated. The
OCD Solutions
Rentz, GA
I had to replace a carbon tank insert in my Matrix and ended up grinding out the old one with a die grinder. It's a dirty nasty job that I wouldn't wish on anyone.
JT_Freeride
Long Island
I need to move it toward like 6" to clear the b pipe You can see a little angle in the front where it's supposed to go. TC put this on for w pfp
OCD Solutions
Rentz, GA
That was my deal as well. Previous setup was for a PF pipe with small tank and I run a B-pipe and stock tank.
I itch just thinking about it.
Ohio
Did anyone ever try prying? I was able to easily "pop" off my battery box when my Envy arrived new. I wanted the battery up front like stock. But that was plexus bonding aluminum to glass.
It did pop off with no damage to the hull though....
JT_Freeride
Long Island
I did trying prying. I also Pried another little mount that held the pipe with a strap and that took some carbon with it. I just picked up a scrapper and a thin blade for my multi max looks like this is my only option.
