- United States
I have an odd setup that don’t see much. I have a Polaris Octane hull, pump assembly, and exhaust(Factory B Pipe) with a Yamaha 760 motor that I just had bored out by Group K to 84.25mm bore. I live at a 5500ft. elevation as well. Below is what I have in it.
Lightened flywheel
Epic ignition with an aggressive stock stroke curve
Dual 46mm Mikuni carbs that are freshly rebuilt with a 130 main and a 100 pilot
New V-force reeds
Blowsion two piece head
MSD coil
Factory B Pipe with the bottom and middle screw closed and the top ¾ turns out
I have some more into it but can’t really think of it now…
My compression per cylinder is 160psi at my altitude.
I am having some tuning issues, I have recently got the low end somewhat runnable, but doesn’t have the pickup it should. It idles great (1200rpm) and my top end rips if it gets to that point (7500rpm). Whats weird about it is that you get to planning speed and give it full throttle, it will hesitate for about 5 seconds then go balls out and starts ripping. I ride with a guy that has a superjet that has a ton of stuff done to it. We checked his high and low speed needles and there about 1-1.25 turns out. Well we matched it with mine just because we were stumped, it feels that it is starving for fuel, well I turn up the screws to 2-2.5 and it starts getting better. My plugs look good a dark card board color. please help any suggestions will help. Thank you
Lightened flywheel
New V-force reeds
MSD coil
