300/440/550 help me with this 550
tiplickhahaha
Hummmmmmmmm
Indianapolis, IN
even before i push the start button, when i go to hook up the positive & negative cables to the battery sparks start shooting.......
like if the neg cable was connected and i go to hook up the postive, sparks from the positive,
same with negative...
when i do get both connections on, nothing happens when the start button is pushed..........
onesojourner
I use a thumb throttle.
springfield, mo
dude you have some electric problems. do you have wiring diagrams? get some and start running through stuff... have fun. or get out now and buy that sj.
adet16v
No like winter
hey i had a similar problem with my 550, ended up frying some wires so be careful, my problem turned out to be a missing ground.
there should be a ground wire running from the neg battery to the engine somewhere AND there should be one running from the e-box case to the engine somewhere. the second is the one i was missing. in my case the e-box was arcing over to the jet power exhaust elbow....
hope you get it fixed.
tiplickhahaha
Hummmmmmmmm
Indianapolis, IN
haha i need a SJ.....
yah i thought it was the ground wires, i know i connected the neg wire from the battery to the bolt ok, maybe it's the box. i'll check that, clean all the contacts and put in a new battery.........
tiplickhahaha
Hummmmmmmmm
Indianapolis, IN
well checked my ground wires...there all good.
hummm time to clean the contacts and put in a right battery..
if i did have a wrong battery (it went to a kawi ZXI) would this happen?
gimmick
sports a beater 550
Pensacola
Nope. Any 12v battery would work. I've jump started my 550 off car batteries many times. Make sure you don't have the polarity backwards. That would cause your sparking problem.
