help, dont want to strip carb screws
so heres my issue. on my 2003 superjet i am tryin to take apart the stock carbs to check for a blockage/ foreign object in the fuel intake area/diaphram area. the 4 screws that need to come out... i have 1 of the 4 per carb . the other ones .. ahh just seem to be in there and i REALLY REALLY dont want to strip them out. any advice to getting these out?
Use a screwdriver that fits into the head very closely.
Then hit the screwdriver with a hammer once or twice (hard!).
This breaks loose any corrosion, frees the threads, and really embeds the screwdriver tip into the head.
Screws should come right out after that. Works every time for me.
njfl
X-H2
Be careful before you take the advice given in these posts. First, you have to be a little more clear. I think Matt is referring to using impact on the metering block (brass block underneath diaphragm cover).
I think you may be refering to the 4 screws on the diaphragm cover though (because you stated 4 per carb). If it is these four cover screws, then the best bet is to use a vise grip.
njfl
X-H2
yes the cover on the rear of the carbs (facing engine) square cover not roundish triangular cover
Ah, the one with the inlet lines built into it. I think they have raised rounded heads. Use vise grips on them at first. Too much banging can break the casting. Use that only as a last resort. when you get that out, there will be a little filter in there. Check that for your main source of blockage.
The other area to look is where Matt is referring to, after removing the thin stamped diamond diaphragm cover plate, you will see the metering block and needle and seat.
Get the right bit and mount it in either a drill press or mill. DONT TURN THE DRILL PRESS OR MILL ON. Just use it to apply strong downward pressure on the screw. Use hand pressure to back the screw out.
Flathead will also work better than phillips.
hermanns
poor
gainesville, fl
I never had any trouble just using the right size phillips and then pushing really hard into the screw to keep it from stripping, worked perfect for me on both carbs, the screws were really tight, but once the broke loose it was no problem, just push hard to keep from stripping
WaHoo_1
Surf Swimmer
Tampa, FL
Big Kahuna helped me do this at Lanier couple of years ago as well when I was really up shizz creek. Although we had to turn and hammer simultaniously (Thanks again BK!):fing02:
Just use the right screwdriver size and push hard. If that is starting to seem like ti isnt working try something else befroe you wreck them. Turning it once and stripping at all is going to make it 10x harder. I had more trouble with the smaller screws inside the carb under the diaphragm.
I also use a cordless 18V Dewalt with a long shaft, wide flat head bit that fits right in, and put the carb in a vise. Then I push very hard on the drill on low torque setting, and give it all its got. Never failed me, I have done probably 12 nasty saltwater SBN carbs that way. Good luck, the internal screws are usually much worse BTW!
WaveDemon
Not Dead - Notable Member
Hell, Florida
you must have been drunk. that was me and ollie. we we're in bk's campground though.:biggthumpup:
SuperJETT
none
If you do mess them up, buy replacement screws from mcmaster, but get the oval head philips screws. There is more meat to grab onto, and they are stainless.
90258A221
18-8SS Metric Oval Head Phillip Machine Screw M4 Size, 16mm Length, .7mm PitchIn stock at $8.60 per PackThis product is sold in Packs of 100
And for the needle/seat/lever arm screws:
90258A178
18-8SS Metric Oval Head Phillip Machine Screw M3 Size, 8mm Length, .5mm PitchIn stock at $4.17 per PackThis product is sold in Packs of 100
Yes you get 100 of each, so you can do 50 individual carbs for $13. Not bad. You can have them in less than 2 days with normal shipping.
WaveDemon
Hell, Florida
was that the year i was there?
i think i remember that... i went by your site and saw reed's ski in 1000 pieces while you and ollie were putting it back together
those screws can be a beeoch!
yep, later that night we were jumping for the top of one house boat to the other. completly sober of course. :woot:
