onesojourner
I use a thumb throttle.
- springfield, mo
I am trying to figure out what is going on with this 91SJ. the problem seems to be getting worse or it could be do to the cold. when you hit the start button you can here the solenoid click then the starter will spin but it is not engaging with the fly wheel, at least that is what is going on as far as I can tell :thinking: . would this be a fixable problem or is the starter done. if its done where is the cheapest place to get a good replacement? ebay?
