Help changing steering cable on blaster
How do you change the steering cable on a blaster? I obviously know how to disconnect it from the steering sytem and the nozzle. I just don't know how it goes through the hull back near the pump. I see that it goes through a white plastic fitting. Do I need to remove the ride plate and loosen this fitting so the cable can slide out?
Thanks
