Super Jet HELP cases don't fit together with the crankshaft in
NW PA
Trying to put together my 61x/62t engine, following the how to in the faq section and the 62t matched cases fit together fine without a driveshaft in them but when i put the driveshaft in it seems like there is a high spot in the middle as if the center bearings are too thick, if one end of the case is pressed together there is a gap on the other of a hair less then 1/8th inch, what is going on here. the bearings and center divider are all aligned with their locking holes and all surfaces were clean.
chriselmore_1
high on resin
san jose ca
sounds like locateing pins in the cases aren't aligned properlywith the holes on the crankshaft. At least 1 pin must be out. You shouldn't have to force it. If you do you'll push the pins in the cases and the flywheel side will pop through. Ask me how I know...
