Super Jet hand holds
tor*p*do
Squarenose FTW
NW NC
um, do you really need 8 handholes?
looks a little like a cheese grater to me.
and more places to catch stuff, body parts, etc.
no idea what you would use the front most holes are for.
just my opinion, A+ for effort
Vumad
Super Hero, with a cape!
St. Pete, FL
My thoughts exactly. I had just seen several AM hoods that were set up like that. Do you think just the 3rd from the front then?
tor*p*do
Squarenose FTW
NW NC
personally, I would go with two each side, a front and back hold
and that should be sufficient.
think about the positions you will get into; you may need a hold on the front or back of the hood
and that is about it.
yes? no?
Vumad
St. Pete, FL
The 3rd from the front is the only 1 I presently would have a use for. I based the positions of the others spaced off that one. I only started riding the SJ recently and am not sure what else I would need. Hence why I am seeking advice. If I did only 2, where should I put the second one? Right now, I am leaning towards doing only the 1.
Vumad
St. Pete, FL
How's this??
Grid
Template
Removed the other side. Readjusted the 3rd hold to match the right side. Going to do only 1 hold per side at the location I have shown atm unless someone provides a good reason to do otherwise.
Vumad
St. Pete, FL
Good advice Mark. This project got a lot bigger than I had planned. I sort of wish I had just done what you suggested. It's working out for me now, but it would have been nice to just cut the hood, cut the liner, add a cup, seal the liner. Too late for me, but good advice for anyone who reads this.
As for mine...
I cut out my templates with a dremmel.
Vumad
St. Pete, FL
I'm struggling here.
I can't figure out a good way to make nice cups short of pouring a bunch of foam and shaping by hand. Any suggestions?
Mark44
Katie's Boss
100% one place
I laid glass over a plastic cup let dry then took it of the plastic cup trimmed to fit in my hood then epoxy and glass it to the underside of the hood.
Mark44
Katie's Boss
100% one place
h
here you go.
