I have talked with Harry multiple times.... It is good to hear your 800 sleeper works well. Unfortunatly, I cannot use the "STOCK" pipe from the 750sxi because the motor is in an x2. I was trying to get it to work with a 650 FPP, that G.K. bored, but with ZERO luck. Harry thought the problem was electrical, but I have since swapped out EVERY elec. componant!!! Harry rebuilt/jetted 2 of the carbs I tried, but both had the same result (RPM capped @ 3800, without "hopping" the pump out of water)
I am @ a loss, but am trying differnent exhausts to see if that FPP is what is the issue.
