GP1200 motor mounts work in SJ?
I read in some thread here that GP1200 motor mounts work as direct replacement for the Superjet mounts.
Any particular year GP1200?
Is it the standard GP1200 or the GP1200R?
Thanks for any help.
I am about to find out, sorta .. I bought OEM 6M6-44517-A1-5B. Which I think are the ones being used by a lot of FL riders. They are not a perfect match but you can either mill the bottom 1-2mm or shift the mounts outward, effectively lowering the height.
This chart gives a pretty good idea of what fits what:
http://www.atlanticjetsports.com/motor_mounts_-_yamaha.htm
good price, I wonder if they are WSM ? couch mounts appear to have more surface area for the rubber to be vulcanized on. Berky said he can not break em doing backies...
I ran these same two couch mounts near the bulkhead and two SJ mounts up front with keepers w/o probs...(keepers have to be modded to fit around couch mounts).
AtomicPunk
Lifetime bans are AWESOME
Largo, Fl
Yes, those are WSM mounts... I was using the chart for reference only.
(I learned the hard way when ordering from AJS to verify if the part is OEM or WSM.)
AtomicPunk
Largo, Fl
More meat.
For comparison.....
They appear to be 1-2mm taller.
i have been running couch mounts in my last 3 skis and have yet to break one....used to replace OEM's once every year/half
raider, venture, GP800..whatever i'd guess gp12 mounts are the same
OCD Solutions
Rentz, GA
I'm running mounts out of a 99GP 800 in my Matrix. They are slightly taller so you have to slot the mounting feet so they set wider and lower but you can fine tune the mounts so no shims are required.
I don't land upside down much either....yet. :biggrin:
Skip the landing upside down part and rotate towards the correct landing position. :bigok:
