SX/SXi/SXi Pro gotta question bout my 750 sxi
hi guys im new to the site just found it but i gotta a little question here is it possible to run an extra pisser fitting from one of the plugs in my head to keep a little water out of the exhaust with out burnin anything up im not sure what all is done internally to the motor but i know it has a westcoast head and it makes 167 psi in each cylinder the head has two brass plugs in it so i was just wonderin if i could use one to get rid of a little extra water without hurtin it any advise would be greatly appreciated thank you
tor*p*do
Squarenose FTW
NW NC
If you dual cool then have dual pissers
Stock single cool and stock pipe will see no benefit from addl pisser
Look for a used coffman for cheap- they make good power
Welcome to the X!!
