kustumk31
woah yeah
- white lake mi
what is the difference between a girdled head and a non.... what are the benefits for both
sflsurfrider said:porting weakens the areas that are known to crack on a 61x cylinder. however, a non-ported 61x cylinder with a b-pipe and stock head can crack. ive seen it. its just not worth running a non-girdled head.
93SJ760 said:I wouldn't necessarily say high compression or overhead pipes are the cause of cracking since one of the girls I ride with just cracked her cylinder 2 wks ago above the front 2 bosses where you bolt the cylinders down. She was running a B-pipe limited. She wasn't jumping or anything like that so I don't think it has anything to do with weight of the pipe but maybe just a casting flaw. She also runs a stock head with stock compression.
Mouthfulloflake said:Is the 62t cylinder prone to this also?
it is a beefier casting right?
Big Kahuna said:usually on the front Right above the corner bolt that holds the cylinder down.
