Freakrider
X247
- Tampa Bay area
61x Cylinders are prone to break on the intake/carb side and the pro tec half girdle is on the intake/carb side...62t's have beefed up casting...
.....im confused.
read the 2nd to last sentence in post #1 and then read post #4.
if it does bolt the cylinder to the cases then its like comparing apples to oranges when compared to the ADA kit.
The sharkfab setup bolts the cylinder to the case and then sandwhiches the cylinder when you torque the head on.
The ada setup just sandwhiches the cylinder to the cases when you torque the head on.
Thus with the ada setup if you un torque the head, the cylinder is no longer torqued to the case.
It takes good force to crack the cylinder loose off the dowel pins/gasket seal and the ADA set up has been proved over time to work well...
I see what you're saying now. I was basing my opinion on pics of broken cylinders...not broken at the base. But I'm curious;
The sharkfab "type" (don't wanna single out sharkfab) ...Does anyone know anyone who's cylinder broke with any type of full girdle?
Not trying to knock ADA. Hell, it's on my ski.
Another thought on the sharkfab style, when you torque down the cylinders, your pulling up on the case bolts right? Or am I out to lunch?
riva used to make a girdle kit like this but the base bolts used to break.
the problem was the upper part of the base bolts were drilled and tapped too far and made the metal too thin and prone to cracking and breaking. IDK if these other companies have addressed the problem.
