- Floridapunk
Following Group K's directions for tuning carbs, I came across something that was different than what I've thought.
GROUP K
"Pressure test fuel system - All pwc utilize a sealed fuel system that has a check valve on the gas tank vent. This check valve (which permits pressure in the gas tank but not out) causes pressure in the gas tank that helps deliver fuel to the carb(s). Any air leak in the fuel system that permits the leaking off of this pressure, will also affect fuel delivery to the carb(s) at low speeds. To test for leaks, follow this procedure. 1) remove the return line from the fitting on the carb. 2) Blow into the return line while sealing off the return fitting on the carb with your finger. This will pressurize the entire fuel system. In a quiet room you'll be able to hear any remaining leak in the fuel system. When you remove your finger from the fitting on the carb, fuel will eventually drip out indicating that the float chamber is primed full of fuel."
Aren't gas tanks setup to vent? Pressurized tanks make sense, but where does pressure buildup release? :Eyecrazy:
I pressurized my tank and found air leaks @ areas where I relocated the internal fill opening. What is the best way to seal the polyurethane pieces? Is there an Auto parts, 'off-the-shelf' product that could work, ie. Seal-all?
GROUP K
