- CT
Finally decided to put my ski under the knife for a winter project.
Ski is pretty much stock besides a bpipe. Going to be widening the tray, 144 pump swap with the 144 shoe. Planning on modeling the ski after this, but a Yamaha blue instead of green.
Here's some progress
Tray out, measures 16.5 now.
Defoamed, pulled all the lines and exhaust. Have to lower the exhaust also. Planning on keeping the stock bilge and adding a separate line for dual cooling
Got the pump and shoe in and all aligned. Went the fiberglass route instead of modding the pump that way I can just swap pumps with no mods if ever need be.
Started by cutting the front hole out and lowered them about a 1/4 inch. Reinforced the back side of the shoe area before grinding. Used thickened epoxy and screws to set the shoe in place once the grinding was done.
Pulled the mid shaft housing and sighted down the driveshaft to get it dead in the center, took about a 1/16 shim under the back mounting holes.
More to come..
More to come..
