Ive come to the conclusion that the 12" wide stock FX1 tray wasn't cutting it after seeing my friends' rockered SN builds. While im at it i plan on doing some reinforcement to get ready for surf. Here is a list of what i have planned in the build. I have been going on it for a few weeks slowly and decided to start a thread on my progress.
-Composite Pole pad
-Wide tray similar to the blowsion one in the picture
-defoam
-fix all the wiring mainly bilge
-reinforce whole inside with extra layers in high stress areas
-dual cooling
-Surf ready hood (stock liner keeps seperating)
-probably more when i find stuff along the way
This pocked style is what im planning on going for
Cut the tray open and started defoaming
3 hours later all the foam is gone some was wet and the exhaust wont work the way it sat.
I took out all the hoses and lines running though the hull. Yamaha got silicone happy and ozed it everywhere so i had to get it all off the hoses because some was loose and would let water through. planning on epoxying in all the tubes
sanded the whole inside of the ski with 40 grit and got ground down all the extra glue
installed the dual water lines and got a 2.5" tube running though the hull now. stock was 2"
-Composite Pole pad
-defoam
-dual cooling
