- Fort myers
I just recently did this mod to my ski, and made a mold so others can enjoy it also. The tray is 2" wider overall, with footholds built into the rear. This part will come in 2 parts...basically both halfs of the tray seperate, split straight down the middle. This is perfect if you're refoaming anyway, and hate glass work. There is still some fiberglassing required, but its very minimal. Basically you will cut along the top of the sides of the tray, and cut the tray out. You then re-foam your tray, lay these guys inside, and lay a few sheets of glass down the middle, and can either lay little strips of glass along the sides of the walls to seal the new part in, or can even use something like 3M panel adhesive ( like this http://solutions.3m.com/wps/portal/...0000_nid=GSNCT3JT87gsQH8HT14PGTglX46N605CXSbl) <<That stuff is no joke!
You will drill some 1/2" ish holes at the top of the footholds, and inject great stuff foam to fill the voids, or you can just be careful to leave the original wall foam in tact, and just carve it to the right shape.
Here is the finished job. (My turfing skills are still developing. lol)
***Please note the back end of this ski looks a bit strange as it also has a VXR pump cavity fiberglassed in, but these parts are made to fit a bone stock FX-1 hull. ***
A set will cost $200+shipping.
