fx-1 reinforcement question
i cracked my hull last weekend in pismo and figured its time to rienforce. i just took my motor out (and no i didnt find the small bolt i was looking for in my black hole, but i did find a bigger one which i have no idea where it came from) and will probably start to lay some fiberglass tomorrow. i was just wondering if there is anything else i should do while i have the motor out since i dont want to have to do this again soon. does anyone glass over those plates that the motor mounts are bolted to on the fx-1's? should those be reinforced or will the mount break before that bond breaks?
[/URL][/IMG]
[/URL][/IMG]
[/URL][/IMG]
LBE
Eddie Would Go.
Charlotte, NC
I have never heard of the plates comming out, however, I glassed mine in. On the edges, I ground them down and continued the glass from the side of the ski over the plates and down to the center.
See pics
The motor is out, your glassing, better overkill than underkill. :fing02:
W
wydopen
Guest
make sure you prep good...you have alot of work before you can lay any cloth
