Super Jet Fully built oem superjet weight?
kid4now
X-H
Miami Fl
First I know there has probably been many posts about this but im asking anyway.
My ski to me seem to be getting heavy. I drilled holes in the back of the hull to check the foam and see if any water would drain out. The foam was dry and no water.
I weighted my ski with the battery and a 1/4 tank of gas and it weighted 306 lbs. So minus 13 lbs for the battery and maybe 5 for the gas does 288 lbs. sound about right for a fully built hull/motor superjet. Oem hull reinforced, wammer 8 hold hood and xscream pole.
thanks,
Brad
Waternut
Customizing addict
Macon, GA
My SN was around 310lbs with fresh 2lb foam and it didn't have any reinforcing. I was running a 16lb battery though. I dont' count gas but I always count the battery.
I would have been stoked for my RN to weigh that little. Mine was seemingly close to an SXR. :biggrin:
It was ridiculous.
