masterblaster
X-H2
Im running 2 year old dual 48s off another ski that sat for over a yr and using a external fuel pump mounted a tad higher than carbs with a single pulse line,with the 2 returns in a T going back through a 2.0 main jet back to the tank. brand new triple stage rad valves from ed,with a r&d intake and angled spacer 1.8 n&s,jets are what ed had in them for another sim engine setup to this one.Cant get him on the phone and his email is full.
I had them dialed pretty well with no filters in prelim tuning with a 15/19 solas.but I noticed the hood had oil all over it above the carbs blowing back?and also the front carb dribbles ALOT more than the rear after a wot blip on the trailer? But the front carb had the most lean looking plug reading even with way more fuel dialed in on the main jet,but to get bottom crisp had way less dial on the low screw,less than half turn?still hit good though.then added prox & outer wears,and a low end prop 10/16 hooker after adding these to try and tune,it was a PITA,couldnt get low end to clean up and had a buncha mud in the mid range before it would clean up in the top end.
Checked the needle and seat in the carb,cleaned and put back in,same issue,still have to check popoff on both,any other ideas?
