Somebody know which brand this hood is?
http://cgi.benl.ebay.be/Freestyle-H...9QQihZ014QQcategoryZ39317QQrdZ1QQcmdZViewItem
Thanks.
Thanks.
Auctioneer a FLAT Freestyle hood with manual actions for the Yamaha superjet starting from Bj. 97 for the current form of the Roundnose. The hood is the inclusive flat Frontnose. It is only easily used, i.e. it has easy color scratches at the lower surface, at which it rests upon the seal rubber. Is however only completely easy!! It actually is flatschneu, but since it has this Macken, I auctioneer it as used. Are weigh only scarcely 5.5 kg. The original hood weighs 11 kg. The hood is auctioneered in front and the catch in the back without mounting material. The nose is for a high-grade steel Bracket. Should have you the Originalbracket still on the jet, then only the front nose must be reground. In the width, there the Originalbracket somewhat more broadly ist.(ca. 0,3mm per side). Loop goes with normal sandpaper or Dremel. If you still questions have then sends to me a Mail.....
