Yea, I thought you might chime in, so I made sure to mention that the pole bolt came out fine on the other boat. I'm almost done with complete teardown (on the silver sqaure), Im working on the carb, its setting in some petroleum cleaning fluid (all internals removed) to strip the paint. Im gonna repaint it, and the motor when that comes out. I got the handlepole bracket off, I thought the bolts were attached on the other side, but they were spinning (I think it was just sealed with silicone, because it popped off pretty easy).
Im trying to get the pole off the other ski (650) though so that I can fix it (take me like an hour, it has some small cracks that I want to dremel out, and fill with peanut butter and then glass over and paint) then I gotta put in some new motor mounts and get it ready.
The silver sqaure is gonna get shot next month, and I'm cleaning the engine and repainting just about everything. I was considering polishing the b-pipe but was worried I might sand off a protective coating.
It should look great all said and done, I'll post up some pics of a before after, Im also gonna reinforce under the handlepole, and re-reinforce on the right front of the boat (a small section is lifting up, about the size of a dollar, rest is sound) and fix the back left corner, returf and mabye get a set of REV's
