I wanted to hear some more answers to basic questions that i have heard many different answers too already. I only ride freestyle surf and want a good bottom hitting motor. Currently it is a 760, hot rod crank, fresh top end, ada head 185, B mod pipe, dual 44s, carbon reeds, 120 jet in water line to water box, spacer plate, MSD enhancer, RAD 2lb flywheel, front only exhaust, etc. I have not jetted the carbs yet from the stock pipe setup.
1. Advice on the carb jet settings and pop off would be appreciated.
2. Is the spacer plate good for anything other than prolonging reed life?
3. ADA domes are 35cc from my 701 (61x) ... is this bad?
4. What kind of porting is good for bottom (pics ?)
5. is a flow control valve better than a restrictor jet (120)?
6. is a static advance any good and where should it be set at?
7. why epoxy intake manifold corssover and intake on cases?
8. are full spectrum 47s too much for a surf boat? I could never get them tunned well on a 701 motor with the same setup
thanks in advance for the help....CARTER
