Custom/Hybrid Fr2 Rickter
Dega
Mike
Toronto, Ontario
Hey guys im putting together my FR2 and this is my first time putting a ski together, i was just wondering where can i check to get torc specs for everything? Also i put in the pump and the motor in and everything lines up great with no shims is there a way to make sure 100% that the motor is aligned properly does it need to be sitting on a special angle?
Any help would be great.
Thanks
eastcoastjumper
James
Long Island
My pump lined up perfect with no shims. I only had to shim my motor. Take the rubber coupler dampener out and your spark plugs and use a small flat edge and check for level around the couplers. Keep rotating the coupler and checking on all sides. Search google for the wamiltons video he does a good job showing how to check it all out.
