Tried changing wires today for the heck of it, put in brand new plugs, and with careful throttle control, I was able to burn 2-3 gallons of gas. This was also coupled with turning the low speed screw down on the rear carb. Then I got careless and was paying attention to other things. I wasn't blipping the throttle constantly at that time and the rear plug fouled. Found out with some older plugs (which were good but used) that if I let the ski idle for 15-30 seconds, it'll foul the rear plug every time. I even tried turning the low speed screw from 1.5 turns out down to .5 turns out and it still fouled.
I didn't replace the needle and seat when I rebuilt the carbs but I did check the needle to see if it was worn and it looked new.
