This ski is the biggest POS I've ever had. I've been riding since mid march and the longest period I've gone without having to pull the engine has been two days of riding and the second usually gets cut short.
It's mostly been the exhaust pipe bolts rattling out now matter what I do. This time I found out that my total loss pickup plate rattled out and gouged up everything.
Well while the engine was out of the ski AGAIN, I decided to do a pressure test for sh*ts and giggles. 3 months ago it was perfect but now the front crank seal is leaking a little. I'll pump it up to 10 psi and then loose about 4-6 psi in 10 minutes.
My question is...Should I be really concerned with this leak? Obviously it'll have to be rebuilt fairly soon but since the season is just getting good, do I need to rebuild it now? Everything else is pretty good. It's just the seal right around the crank shaft.
