- Brigantine, NJ
Check this out (not mine):
http://cgi.ebay.com/ebaymotors/Kawa...egoryZ124112QQihZ011QQitemZ320076000553QQrdZ1
Cool articles. The dyno chart shows the Coffman's and the Factory Pipes actually lost power over stock. Think that is right?
Aaron
never trust dyno readings given on the x
sounds like a sweet setup for a 550 motor. Right now I got about 4 skis in my garage that are at 85% done or so. Where do you ride at when you come to sac? You gotta check out the all out 550 freestyle/low end power build we are finishing up right now.jetski9010 I thought you would like to read this:
I was sponsored by a company that was marketing/selling them called Dycorp, I used them on my race 550's and blew them up a lot until I figured out how to make them live. It took 112 octane w/200 lbs of cranking compression, set the timing to 18 degrees, and the biggest trick to keep it from seizing with the dual cooling lines, was to set it up with .010 thou of piston clearance!! I had a rider that won all but one race in a 16 race season after I found out how to keep the 550 from seizing the piston a couple laps into the race...If your going to run this pipe on pump gas YOU MUST USE STOCK COMPRESSION HEAD and run .008 piston to wall clearance. This pipe by far was the most HP I ever made over any single pipe I tried to run, but not fun to install, like a puzzle, this before this and you needed to do that before this....so I do have to say It was the pipe that made me a little crazy, but won races like no other!
I am up in the sac area a lot going up tomorrow my sisters lives up there we should go riding sometime.
