- swedesboro, NJ
Putting a 148 in footrocket. Wondering if anyone has had to grind the hull to make it fit. Reduction nozzle is hitting the top of pump tunnel.
Thanks for the heads up. I should contact krash.My tray doesn't dip down like that, there's a decent size gap between my pump and the tray. Have you talked to Krash about it? You could grind the rib down on the pump if you just need a little more clearance.
Grinding the nozzle is the next step but I don't think it will be enough.Grind the nozzle!
