CarFanatic
Fiberglassing Newb
- Cincinnati, OH
ok, so I"m making progress on my install. I got the holds cut out and the foam dug out. First off, man thats alot of labor just to pull the mats and get rid of all the sticky residue!!! The easiest part was cutting the holes!
I got the foam dug out
NOW!
here is the part that kinda made me mad. I got cyclones, used the templet from wammers site. Meassured 5 inches in and made the cut. easy. The foot holds however once I layed them in the cuts, I noticed they weren't identical, and didn't sit very good against the body. So I had to adjust the hole for them to fit alittle better. The left foot has a bigger hump to hold your foot then the right one does. Its noticably smaller. Then The damn things weren't trimed right. there is alot of excess material like they didn't cut it off. I'm assuming this was doen incase you cut the hole to big?? But now I have some over lap that I guess I'm going to have to trim to get a cleaner fit. I"m also worried if I trim the back part, which is were it need triming, there isn't going to be more then 1/4 inch or so of material to glue up to the hull....??:shocked: I dont think thats enough.
Lastly These holds dont lay flat again the hull all the way around. I'm afraid if I glue them in and take the screws out that they could pull away?? Is this possible?? I don't know how stung this epoxy glue is.. But There will be some tension on them, simply because the holds don't sit against the body... If I leave the screws in though, it be harder to get them out if I had to ever take them out. Plus I got button head screws, not counter sunk, to take out because I planned on epoxying over the holes??? I assume these have to be installed good and strong because they will take the abuse of pulling and twisting with your feet. Please help. :theyareontome:
NOW!
