Flywheel photos need answers...
casanova992
4U2NV
Margate, NJ
good evening gentlemen, I'm stumped at the moment. My ski is finished, however, I still don't have spark... I checked my wires over anmd over again.. I used my meter, to confirm things, I gotta be doing something wrong, or overlooking something. Meanwhile, i think my bendix is starting to go. Well besides that, I keep thinking about that flywheel situation. If I have the correct flywheel on my 62T, here are the pics of the flywheel that is installed, and the one in my hand. the only diffrence I can see are diffrent numbers.. Please help me guys...
Ciao,
A desperate rider:banghead: :17: :17: :17: :17: :17:
norcal ex
X-H2
San Jose, CA
the only way i know how to tell is from the other side. a 62t flywheel will have a magnet allll the way around while the 61x has 4 seperate magnets....i will be doing a bottem end rebuild/ engine install tonite...:biggthumpup:
casanova992
4U2NV
Margate, NJ
Do you think thatz why I'm not getting spark, letz just say the flywheel that is attached to the motor has the 4 seperate magnets.. meaning wrong flywheel right stator??
Err...a 760 flywheel will not work with a 62T stator.
Pull the flywheel, post pics of the stator, installed, and pictures of the inside of the flywheel you are trying to run.
WAB
salty nuts
coastal GA
If you have an OEM 96+ SJ motor w/ stator there, that is the right flywheel that's on it. The other is a 760 flywheel, on those the stator mounts to the inside of the flywheel cover. If you had a 61x stator you might have some problems with that 62t flywheel on there.
Did you remove the stator or adjust it any? Is that the one that came on the motor? Do the 2 lines on the case & stator line up?
Did you try cranking it with the black & white wires for the start/stop switch unplugged?
casanova992
4U2NV
Margate, NJ
I tried cranking it with the white and black unplugged,it cranks but no spark... the engine is out of a 94 raider. I bought the stator last year from magoo, but don't know If I mentioned 62T 61x, or 94 raider. I'm currently in the process of trying to remove the flywheel, what a biotch.. I would think if the timing is off from the 2 notches not lined up, it would still spark.. I'm going to try tonight when I get home, I have a puller, but the dam thing still isn't budging, I heated it up a 1/2 a second 2, still nothing, then I tapped it lightly with a hammer, nothing again.. I left the puller on it last night, hopefully the pressure will make it easier tonight...I doubt it, but at least itz wishfull thinking...
It would indeed still spark. You need to test the stator, then move on down the line to the CDI, and the coil and wires.
casanova992
4U2NV
Margate, NJ
well, I must be overlooking something, or doing something wrong.. or the stator is shot.. The coil wires are new, the solenoid is new, I even took my entire brain box out of my running waveblaster, and still no SPARK.. Where is obey one conoby when I need him...???? Errrr..Anyone in the Cherry Hill area, Philly area, that could help a brother out..
Uh...that would be Obi Wan Kenobi you're looking for, in the proper spelling. :)
First, you should disconnect the start/stop switch and see if you'll get spark then - those switches are known to go bad.
After that, like I said, you need to perform some simple electrical testing on the stator, the coil, and the coil wires.
There arent' many parts involved in the ignition.
casanova992
4U2NV
Margate, NJ
I wonder if itz one of my grounds? I'll play with it till sunday, then I'm swapping motors for the time being... But then I feel like I gave up, I'm no quiter.. dam this sucks...
douglee25
m3booooy
South Jersey
Me!:Banane01: I live about 10 mins from Cherry Hill. Bring it on by with your torch and puller and we'll get it off.
Doug
215-205-7799
douglee25
m3booooy
South Jersey
This is courtesy of Jetskisoultions. I copied it from PWCtoday.
Well, the season is here. Since so many have electrical ignition questions, I thought it would be handy to keep this "quick test" guide at the top. I hope this helps everyone make a quick diagnosis
This applies for most any ignition problem with the 701 61X or 62T series ignition components.
1. check the AC output of the "charge" coil. Don't get confused with the term "charge" coil......this is what Yamaha calls it, as it "charges" the cdi capacitor. This coil can generate in excess of 500 volts!!
Dis- connect the brown / white trace wire and ground wire and connect the meter leads to these wires, and while cranking the engine, observe the reading. You should have 30 to 50 volts AC depending on how good a battery and starter you have.
2. Check the pulser coil output. It's job is to tell the cdi when to fire the energy stored in the capacitor. Dis- connect the white / red trace wire and connect the meter leads to this wire and the ground wire. You should get a pulsating 4 to 5 volts AC. (ps, an analog meter is best for this test)
3. If you are having problems with the battery not recharging, then dis- connect the two green wires and read the cranking voltage produced by the "lighting" coil. This coil's name is a throw back from the old enduro bike days, when the manufacturer would add a coil to the stator to operate head, brake and turn signal lights....without a battery, and later with. Anyway, you should see 6 to 10 volts or so here, again AC. This coil puts out close to 20+ volts AC, to be recitified to DC and regulated at 13.5 or so to recharge the battery. This coil is rated to generate up to about 2amps of charging current. This in mind, beware when running two bilge pumps.....a battery going bad (high internal resistance) and two bilge pumps running for a extending time is just enough to cook a lighting coil.
4. Ignition coil. Not many folks do not have a meter capable of resolving the almost dead short of the primary on this coil. But if you do, the resistance should be .078 to .106 DON'T forget to subtract the meter leads resistance by shorting together and subtracting, or adjusting the zero ohms pot, if you have it. Also, remove and insert the leads in the sockets to clean the connection.....I often see 1 ohm or more go down to .2 or .3 by performing this task.
NEXT, check the health of your spark plug wires, or high tension wires as the Brits like to say. The only way to test them properly is to remove the boots and get to the end of the wire. You can try jamming the point of the meter probes into the end, but due to the dirt and metal dust, it often does NOT give a solid connection / reading. If you have electrical contact cleaner, by all means spray with that first. You should read 3500 to 4700 ohms, or 3.5 to 4.7K ohms STEADY....while flexing the wires from end to end. If you get any fluctuations, they are bad...IE breaking up inside, turning to a high resistance powder of metal and rubber. I have seen bad plug wires cause problems with idle and low speed only, mid range only, and high speed only, and every combination thereof. Very strange !!!
If all these check out good, then I would swap the cdi with a known good unit....and known good means just what it says.....you have had it running in your boat, you removed it, and you put it away..The only other known good is a new unit. I have heard many a sad tale of days of trouble shooting with no luck, only to find out that the "known good" cdi your buddy gave or loaned you was not good after all.
Another interesting point is the "sparks when you let off the start button" syndrome. This always means on of two things......the cdi is bad, or the pulser coil is bad, or the wire from it to the e box is open.
Another good point to keep in mind: it is very possible to have two problems going on at once. One, like bad plug wires may have going on for a while, but no creating any major problems....the performance degrades so slowly you really don't notice it. Then, the charge coil insulation starts breaking down, or the connection from the winding to the terminal posts goes bad and starts arcing over. The two combined creat havoc, and can make diagnosis difficult.
After seeing so many stator coils have a good resistance, but test bad....I strongly advise against using resistance readings alone a gauge of health. Perform the cranking voltage output test!! Resistance readings are still useful for some work, so here they are for 61X and 62T:
61X: charge coil, brown / white trace to ground / black: 365 +- 10%
Pulser coil, white / red trace to ground / black: 12.6 to 15.4
62T: Charge coil, brown / white trace to ground / black: 497 to 608
Pulser coil, same as above
Lighting coil, green / green wires: 1.14 to 1.40 Since this coil is not grounded in any way to the stator frame, you can check this coil for leakage to ground (indicating bad insulation) by measuring between either green wire and ground with your meter set on the highest ohms scale, usually 20 to 40 meg ohms. If you get any reading, the coil is going bad.
There are other tests we perform to positively verify a coil's health, but the equipment is specialized and the proceedure is beyond the scope of this posting.
A note about the ignition coil: CDI ignition coils are much different than the coils in many cars, especially older cars. Those coils operate on the "collapsing magnetic field" principle to creat the high voltage. CDI ignition coils are in essence "step up transformers" simular to any any plug in wall transformer to operate various devices. The output is directly proportional to the input.
Another interesting proceedure you can do to gain more information about your coil's health.......hook your meter up to any coil, set it on the highest scale, and observe the reading. Leaving it there for an hour or more and come back and see what it reads. A lower reading or higher reading, or a reading that will not stabilize indicates a bad, or going bad coil. This may only work with better quality meters.
Some of this applies to Kawasaki too. If you want more info on Kawasaki, as well as Polaris, please contact me via e mail, NOT pm.
As most of you know, we can restore any stator and ignition coil to better than new condition. Please check our web site, or give us a call if you need more information.
