Flywheel Holder Solution?
I do not have a flywheel holder to remove the flywheel from my SJ. Where is the best place to get one? Are there any alternative tools to remove the flywheel?
Thanks
Mouthfulloflake
ISJWTA member #2
NW Arkansas
I usually use an impact, but I have used the rope trick a few times with ZERO issues.
granted there are some people that fawk up an anvil with a pillow case, so I understand your sentiment.
I have resorted to the rope trick in the past. The idea makes me a little squeamish, but has anyone had any actual problems as a result?
tightithrash
Zack Bright. I Thrash.
Oceanside, CA
i put a nickle between the fly wheel and the bendix............i herd that since the nickle is a softer metal.........it doesn't fauck it up hahaha.
i haven't had a problem...........
we used a rope on a buddy's ski. preeeeeety sure that's why the motor is now frozen. possible bent rod. dont do it.
yes, i think it has ruined some good ropes...I use an impact also with a auto zone harmonic B puller....a yamaha mechanic once told me that the rope trick could possibly twist a unwelded crank, but many have done it w/o issue...
