Flywheel... HELP!!!!
casanova992
4U2NV
Margate, NJ
I can't seem to get my flywheel, AGAIN!!! The reason why I must take it off is, Magoo told me the diffrence about a 62T 701, and a 61x701 fly... Unless of course these numbers mean anything to you guys.This is the number on the flywheel that is installed on my 62T F4T316, and here is the other one F4T323.. I just wanna make sure I have the right Flywheel installed, since I wasn't getting spark..
Any info would be appreciated..
Thanx
Vince
SuperJETT
none
Are you having trouble getting it off or identifying it?
To get it off, use a flywheel puller and if it's really stubborn, tighten it up then whack the puller bolt with a hammer.
casanova992
4U2NV
Margate, NJ
I have a puller, thatz what I'm using..No sweat Scott! I need to determine if itz a 62T FW...Then maybe the spark, is from a bad ground... Any other info
Mouthfulloflake
ISJWTA member #2
NW Arkansas
Not to be insulting, BUT
make sure, the center screw in your puller, doesnt have the pointy cone tip on it, on my puller, that cone actually pushes the flywheel.
Ive made that mistake, so please dont think im insulting your intelligence!
WaHoo_1
Surf Swimmer
Tampa, FL
no worries Mouth...didn't take it that way bro. I was researching threads for an issue(s) and was just wondering the flip side of fs geek's statement.
(The X wheel will not fit on the T stator.)
I've already got the new t fw on and a new bendix, but was experiencing some no spark issues. I'm thinking possibly the stator. Still reading and researching...
