mk1
PUDDLE - BLASTER
Dudes , about to install a flow control valve to my ski with a jetmaniac 760 BB engine and a B pipe. Where exactly do i hook it in..? Any photos of your skis with valve in situ appreciated.. Thanks...
Thanks, will you have another go at uploading the photos please ..It’s used to control water flow into your pipes stinger.. so install it RIGHT before the stinger nipple on the pipe..
Photo won’t upload
Thanks, and where exactly do you recommend to fit the restrictor.?Better to use a 2 mm restrictor
At least have one in the line
I had a fcv fail open and flood waterbox
Same line going to the stingerThanks, and where exactly do you recommend to fit the restrictor.?
[/QUOT
Guess site won’t allow sizing of screen shot pics so can’t post it.... here is another ski I can link.....
Another variation on restricters I’ve run, use A 2mm restricters after the flow control valve....Restricter regulates how much water goes into stinger and the fcv regulates when it goes in to restricters
If you run other restricters in your other cooling out lines then put the restricter before the fcv so your system pressure stays even and isn’t all dumping to the fcv.....
2014 SFS Superfreak Titan -9
2013 SFS Superfreak Titan -9 Runs perfect and is in great mechanical and cosmetic condition. Been mostly a freshwater ski and has zero corrosion. The only issue is the pump housing is cracked, however it doesn’t effect performance. See pictures for specs. Located on Kingsley Lake,FL. Will ship...www.x-h2o.com
