Flat water Back flip try video
Marshj
DarkHorse
Ann Arbor
Yes thats a great motor\hull setup,and i think my impeller matches very well the whole setup.I've ridden lameys of some buddies here in brazil and didn't like better than my ski,i think it's because they haven't chosen the right impeller,so the ski doesn't get that snap!
Definatly! Looking great. :cheer: I did a show with malone in july, and studied his flip attempts closely. I think if you came into your wave slower, you may get further around. And the light hull is a must!! Keep it up
All the Vids I have seen, Malones ski for 2005 looks like it flys out of the water like no other. I can only imagine what his power to weight ratio was for the finals. For what it costs to build a Lamey, I would much rather just buy a light weight hull, I think Lameys are overated, but if I had the $ I would probably do it too.
I already have a lighweight hull.Now I'm concerned about some motor mods,like MSD,or stroker crank,but I don't really want to pass the amateur 800cc limit.
waterfreak
I had a vision!
s florida
it don't really matter cause your After Market hull isn't legal in amateurs anyway!:cool2:
keep up the good work. You should of got Sergio's backflip hull. Besides having a lightweight hull, it really helps to have a shorter custom hull for this trick
Sharky
www.fpjetskis.com
Well done, nice attemp, do you run the trim system he sells it is trick.
Gave my XFT ski to a mate to ride in 1 foot swell and he did a one footed back flip second go, he loves my XFT hull and wants to buy one to, have you tried 46" carbs i run a 760 ported with 46 and a 13'17 prop runs sick, just i am not as good as you on the flat water,
way to go..........
F
Freestyleriverrat
Guest
Are Lamey/aftermarket cylinders legal in amateur class? Anyone know?
F
Freestyleriverrat
Guest
Sweet.....I am sitting at 780cc on my standard stroke lamey PV :cheer:
