- atlanta ga
i just bought this today as you can see the outer flange fits inside the stainlees pipe. it is just tack welded in .does it need to be welded all the way around. also it came with a rubber gasket do you use this to stop leaking in ski,or5200,epoxy and filler. ive seen a few people use these i just dont want water to leak in boat because its not welded all the way around. but then again it will be out side the boat. any sugestions
