- Winter Park
So I've ridden a standup no more than a half dozen times, on a superjet and a super freak, and I've decided to go all out with my first build (mainly bc I'm addicted to projects)
So I picked up a 04 superjet with side damage and a crappy foothold job.
Then started cutting the tray and footholds out
Defoaming sucked but the pressure washer helped
So I started cutting and glassing and sealing everything
This little bit is awesome
My drain plug idea, i wanted it to be flush
New footholds- rev
I dug these out to reuse for my SN ride plate
Exhaust and pvc pipe secured
Early stages of making my own front foothold
2 part expanding foam sucks to work with, but I have the Home Depot pink foam under the tray
Going with a CarterB rocker kit, he lives near me and let me check out his gen2 and gen3, decided on the gen3 to reduce splash.
For the drain, I'm using a versiplug max in the pvc
Motor and paint has yet to be decided, I'll cross that bridge when it comes.
I already built my 144 pump, gonna change the prop to a 9/15 most likely
It also helps that I work for JetManiac when I'm not in school, been there 2 years and just now decided to build a ski. I get bored easy and need projects, usually building and flipping cars or messing with dirt bikes.
To be continued..
New footholds- rev
To be continued..
