All it takes is a head high wave or bigger and some balls. The guys who have been saying that for a while weren't kidding. I finally grew the sack to try it.
771 Jetworks Big bore----62Tcased/61Xcyl.----with case porting and brand new blackjack 44's installed.
Running OEM 760 intake with Art's reeds in OEM cages. Art's domes for his 771 motor. Factory MOD B pipe with homebrew ported headpipe and manifold. MSD enhancer and flow control.
I need to dial in the pump now since this motor is making the pump cavitate bad!!
NICE! Motor is a bit more radical than my more "off the shelf" ported 771. I should have my fixed steer SN on the water within a week or two, hopefully less, with my Tom's hood, Tom's nose, Tom's holds, and Tom's tubbies, all painted up and pretty. Can't wait!!
Got my nosepiece in from Tom21. Hopefully I'll get it bolted and glassed on to fix the nose on this beast. Did some depth testing with it a while back and ripped it off.
New nosepiece looks real nice though.
I swapped the blackjacks out for some OEM dual 38's. The ski is much better on gas and the power is just fine. It might even have a little more off the bottom if anything.
How does cutting a few inches of the back effect the ski for carving waves and handleing? Better or worse? Only seen this ski in action for a little while at brig and it looked good.
Finally got to some fixing today. Had the skis on the back burner for the past month since I broke my wrist. The lightened OEM flywheel I had in this ski took a crap after one day of riding at the brigantine ride. Cracked the hub and wouldn't spark. I took the TBM flywheel out of my 865 and put it into this ski instead today.
The plan for this winter is to unload my other two skis and keep this as my only ski.
Jetworks 771
Dual mikuni 38's with kawi 750 reeds and stuffers
Factory B mod
MSD enhancer
TBM flywheel
Solas Mag pump with 11/17 hooker
I should have a funny paint/vinyl job on the way this winter. Special thanks to my riding buddies for coming up with the paint scheme. Need to sell my other stuff first though to get some money together to play with skis again.
