FL-cracker
X-H2O
- old exit 72 Melbourne
Ill make it rain on these hoes! Being scared of going backwards is a thing of the past for me.... you wont be able to resist yourself! :biggrin: Its going down!
this is gonna be sweet.
now we just need the surf to cooperate with us so we can have a repeat of the madness of that day at the j/k flip off. that was ridiculous, stupid dumb!!!!
I wanna go, now. Is it choppy this afternoon?
i dont really need it, but when you spend that much $$ on something, you want every little accessory that comes with it from the dealer... know what im saying???????????????? LOL
it's always choppy in the afternoon... sometimes it cleans up right before dark due to less heat...
It's the heat of the day makes stuff stat moving around
Backflips everywhere.
I think a friend of mine will have his 26ft Donzi/proline out there for the day to chill on as well..... Maybe some chicks :biggrin:<--- the guys married... but i got some girls that like to hang
Anyone gona have a Vidio Camera.... this could be epic!
Slutty.... your soft as Baby poop :biggrin:
Mike your the freggin man!
WTF :shrug: Let me see if I got this straight. The heat makes the wind blow onshore? I know the sea breeze usually pics up as the day goes on but I never thought that heat actually makes baby waves (chop). J/K
well... it's a little more complicated than that... :thinking::thinking::thinking:
heat of the day is what causes a lot of the wind to blow..
[SIZE=+1]The source of wind energy is solar heating. The sun heats the earth's surface unequally. The heat gathered by land masses and large bodies of water is also released, thereby warming the air above them. However, water does not heat up as quickly as land. Because water has a higher heat capacity than land, it requires more incoming solar radiation to heat a body of water to the same degree as it does to heat a land mass. Water also releases its heat less readily than land. As a result, in response to solar heating the air over large bodies of water typically remains cooler than the air over continental land masses.[/SIZE] [SIZE=+1]Along the coast, sea breezes form when the light, heated air over land masses rises and the heavy, cool air over the ocean moves onshore to replace it. At night, when the land cools, also cooling the air above it, the process is reversed. The warmer air over the ocean rises, allowing the cooler air over the land to move offshore to replace it, creating a breeze going out to sea.[/SIZE]
that pretty much sums it up... that's why it's always glassy and no wind at night... werd
I'm supposed to take it easy. the doc wants me to glue a brace to may nose.Backflips everywhere.
I'm supposed to take it easy. the doc wants me to glue a brace to may nose.![]()
bring it. :cool2:I won't be doing anything that involves the word back or barrel ( Imapuss). I have a cascade helmet that your more then welcome to wear for the day (Sun) if you want.:bigok:
bring it. :cool2:
