Fire Extinguisher and tow rope front foot hold
Thank you
Rubber latches for coolers from Amazon. Never break cooler hinges from Amazon. Several layers of 3/8" under pad from Jet Maniac. Cut diamond turf from Hydro turf. Would use molded turf next time to better match the factory turf. Stainless bolts from Ace Hardware. Large bling washers from Jet Maniac. Fiberglass cloth, mat and resin from auto parts store. Pole limiting kit from Jet Maniac. DIY hood strap and buckles from Ace hardware. Hole punched straps and used M8 mounting bolts to hold with bling washers. Used a 3" PVC pipe and a 2x4 as the original mold. Pulled that out then made end caps and mounting base flanges. Added glass layers as needed. The fire extinguisher slid right into the 3" pipe, so that gave enough clearance to turf the interior.
Great work!!! I would like to see a pic of it without extinguisher and tow rope in it, thanks!
Inside photo.
I molded a cradle to keep the extinguisher in place when the tow rope comes out. It also makes it easier to put back in. Lined with diamond hydro turf. I drilled drain holes at each end of the extinguisher cradle and the lower corners of the tow rope area.
