Finally got my Christmas Present - now about those '05 carbs
beachedflunkey
wavejunkies
Virginia Beach
I don't know how much that hex driver will help, but seriously, pull the plugs out, adjust the screws where you'll need them, and put the carbs back in your boat. If you are running a somewhat basic setup, you should be able to set it and forget it based on someone else's settings.
michael950
for me to POOP on!
Houston, TX
Thanks, I think I will do that and see if I can pick up a nice set of 44s for next season. I would like to get an ADA head before the carbs (and reeds).
Why did you "have" to send them to JSS?
Marshj
DarkHorse
Ann Arbor
On my '04 i removed the caps and adjusted off the ski.
After a year i got annoyed with having to remove the carbs. I took a small saw and cut 1/4 inch off the tube the screws are in. This way i can adjust then in the hull. Works great- Cg Racing helped!!!!
