Hey im going to fill the crossover on a 760 manifold what is the recommended stuff to use on this.. I was thinking Jb weld last time i used devcon and it seemed to shrink out in some spots...
Yes, stock 760 intake manifolds have a crossover in them, you can fill them with JB weld, just over fill then lap/sand down on a flat surface w/240g wet & dry. Just make sure you set the manifold after filling in the sun for a day to fully cure or 1 hour in the oven at 200 degrees.
I have experienced the shrinking with devcon as well
However i have heard they changed there formula and doesnt do it as much as it used to
myself i always use jb weld
I just wish you could buy it in large amounts
