SXR Factory Pipe
I am running my factory pipe plumbing according to the factory pipe instructions. The pisser that goes from the top of the head pipe and off the back of the ski is there anyway i could transfer that off and put a water bypass fitting at the front? what needs to be done to do that? also could i run three separate passers off my ski rather than running a "T". Therefore a pisser off my head, a pisser off my head pipe and a pisser off the stinger, would that work?
Cannibal
Tasty Human
Summit Lake, WA
You supply water to the stinger, that's why there is a "T". You are not taking water from it. The pisser is there to add more water since you are not running much water in that wet pipe. It helps cool the hoses and put more water in the waterbox to help quiet it down.
Here's how I run mine:
I have dual cooling from the pump. One hose goes to the exhaust manifold to supply the engine with water. The other hose supplies the bottom of the head pipe. Off of the head goes to a pisser overboard. Off of the head pipe goes to a "T", one side goes to stinger, other side goes to a pisser.
