factory b pipe in rn. What are best jetting settings
curt248
01 superjet 94 fx1 97 xp
Chicago IL
I have a 01 superjet rn. It has the factory b pipe, ms? ignition changer, flame arrestors, carbon reefs.
It has a lull at about 2/10 throttle. It then comes back with a surge at 3/10. What changes to make with the carb? I'm in Il (chicago area). Temps have been about 80 to 85.
Please help.
I'm looking for a starting point (how many turns out etc.)
Shifty
- SuperJet Thursday -
This is an excerpt from Factory Pipes website on the limited pipe...
These adjustments are for 730 feet above sea level on a stock engine with aftermarket flame arrestors. Your specific adjustments may vary depending on engine modifications, fuel, altitude and other variables. Please consult a qualified technician if you are not familiar with tuning your carburetor. These changes must be made prior to running the engine.
Main Jet: 135 (130 stock)
Pilot Jet: 70 (stock)
High speed screw: 1 2 turns out from closed
Low speed screw: 1 1/4 turns out form closed
Needle & Seat: stock (55 psi)
Spring: Stock (95 gram)
DC SUPERJET
Half a roll
Lake Michigan
I went with the settings factory pipe recommends and mine runs great, and I didn't have to change anything. I would at least start there and tune accordingly.
curt248
Chicago IL
Anyone know what high speed screw out 1 2 means? Does that mean 1 to 2 turns out? In the factory jet pdf it looks like the 1 is in normal black and the 2 is in grey (maybe they meant to delete the 2)
