FlightPlanDan
Don'tTrustAfartAfter50
- Crescent Beach, FL
I've read the tech-faqs and don't see an answer.
I'm having a carb tuning issue. Just installed a B-pipe and an MSD enhancer.
The low speed seems good. braps nicely from idle.
The high speed is my problem. Re-jetted stock mikuni 38's with 75 pilots and 135 mains.
I'm out over 3 turns on the highs, but when I check the plugs after a wide-open cut off, they are clean as a whistle. No charcoal color, not white, but clean as if they were bead blasted. (I've always been told that a tan/brown/charcoal color is optimum.White lean, black oily-rich)
Could this be caused by the pipe tuning? The top and middle water jets are closed and the bottom is open about 1 turn.
I had no problem when I did this to my wifes ski. (no enhancer). It took about 30 minutes and it's been good ever since.
Thanx in advance for any input!
Dan
Dan
