Hello,
My sx 750 overheated and turned the top of my engine black. I think it blew the head gasket, but i am not sure why. I took off the heads the looked at the head gasket, i will post pictures today as well, and it was slightly bent, but im not sure what it is supposed to look like.
I had a problem with all the blots coming out of the exhaust flange the day before for some reason, and put the high temp sealant between the flanges and bolted it back together. Any it looks like on the inside of the cylinder walls there are small reddish flakes i can wipe off, i dont know if it could be part of the sealant somehow leaked back into the motor or what? I am not sure since the exhaust flange came off it it occured because the motor overheated and it backed out the bolts, or maybe when the exhaust came loose, it is screwed up the compression and blew the head gasket which caused it to overheat the next day? Can it overhead if the head gasket is not sealing properly?
Also for engine cooling, is there a pump to pump water to the motor, or does it shoot it from the jet? Any help to go through the cooling system to ensure that it is working properly would be great.
Thanks
Thanks
