- Fort Mohave, AZ
OK that's what I figured, standing on it in my garage it feels really funny, I think I'll take off a fee more inches tonight.
Is there any kind of scupper delete/block off/replacement etc. for the micro? Mine looks like its just aching to leak, and where I ride there are huge no wake zones and areas where I sit and float a while. I think the ski will just fill up with the scupper on it since it looks like it seals very poorly, the flap has like a 1/4" gap... Any advice? Thanks
They can be found at your local plumbing supplier. I think I recall seeing someone using an aluminum plate in place of the flapper with a ball check on it.
Another question, what did you guys use for tank/water box/battery strap mounts?
Here is a pic of my issue, midshaft is pressed in with 20mm out the back per spec using the midshaft and midshaft housing supplied by EME. Midshaft carrier is from a Waveraider, but all are the same across all later Yamaha's. Using raider motor mounts (too tall by 1/4" so I need to replace them), raider bedplates (again same as a Superjet), and Raider couplers. @tatronation I checked out your thread, unfortunately I can't do the pump mount like yours as there is no hull at the rear pup mounts... Any ideas? Thanks
