Super Jet Electrical Issue - Please Help!
DC
Let me start off by saying Chris @JetManiac has been a big help but I don't want to keep flooding his inbox with questions when someone may have had this exact issue. Also I have gone through tons of threads on here but haven't found anything like this. This could also help someone out with the same issue in the future. My ski is a 2008 SJ, I have lots of mods but the only ones that pertain to the electrical are probably the ATP Epic ignition and dual bilges (tidy bilge). Here is the problem:
Ski won't turn over unless I bridge the solenoid w/ a screwdriver or put power directly to the solenoid (bullet connector on brown wire to battery side of solenoid)
Sequence of events:
  • Ski won't turn over with start/stop switch
  • Jumped red/brown wires outside of ebox and got nothing
  • Opened ebox, checked connections, replaced fuses, jumped red/brown and got nothing
  • Put brown bullet connector from solenoid directly to positive post on solenoid and it cranks
  • Reconnected start/stop and ski turns over
  • Put ebox back together and of course zip tied everything nice and neat, ski WON'T turn over with start/stop OR by jumping red/brown wires out of ebox
It's almost like the ski will only turn over once I have either bridged the solenoid with a screwdriver first or put the brown bullet connector to the positive. I have already replaced the solenoid with a used OEM working one from Chris. Any help or direction with this would be much appreciated. Thank you.
